    Nov 2013
    3
    AMCOR HD320H Dehumifier - clanging / rattling compressor then Klixon trips
    I am pleased to find this forum and learn a little about refrigeration as I figure-out if my Amcor HD320H dehumidifier is fixable.
    Out of the blue it started to clang and rattle loudly. I have identified that the blower fan is working fine.
    Attached to the compressor I have identified a Murata positive temp coefficient (PTC) motor starter thermistor and a 'Klixon' thermal trip. On powering-on the machine it runs for some seconds; sometimes quietly but generally rattling a bit than it used to. Then I hear a click, probably the Klixon device, and it shuts down.
    The compressor is labelled:
    TATUNG Co. R134a
    FH300Y2-E
    Sparse detail I know but is this enough information to identify a repairable prospect?
    Sep 2003
    ISRAEL
    72
    4,248
    Re: AMCOR HD320H Dehumifier - clanging / rattling compressor then Klixon trips
    The company doe's exist for many years, someone must have bought the brand name, product most probably made in china [ low quality]
    Compressor is chinese by model no. from your description, it sounds as the compressor is on its way to compressors heaven.
    Check with a fridgy the cost of replacing it. a new dehumidifier might cost just as much as the cost of replacing the compressor.
    Nov 2013
    3
    Thanks, so it seems that the fault isn't one lf the devices plugged into the side of the compressor; the Klixon and the thermistor.
    Oh dear, it's off to the junkyard with it. Bathrooms just aren't as warm and cozy without a dehumidifier so I'd best get shopping for a new one.
    Nov 2013
    3
    Ah! I just found that if the unit is tilted about 30 degrees off the vertical the compressor ceases its rattling. I may be able to squeeze a little longer out of this machine. I'll quite likely find the extracted condensate no longer falls into the water carrier - I am expecting a wet floor sometime soon.
