Results 1 to 14 of 14
Thread: Recovery Units
    Feb 2006
    derbyshire
    610
    Recovery Units
    anyone know of high capacity oilless units yet,meaning 3/8 hose fittings, about 50kg per hour,none of theese wonder machines the size of a shoe box that do the world on paper but sod all on site,got some good recip ones but getting a bit old now, cheers.
    Feb 2006
    11
    Re: Recovery Units
    I know of some high capacity recovery units. Got a lot of refrigerant that needs recovering?
    rbartlett's Avatar
    rbartlett Guest
    Re: Recovery Units
    you need to use the old push pull to get anywhere near their figures..
    cheers
    richard
    Feb 2006
    derbyshire
    610
    Re: Recovery Units
    hi there,do about 600kg a week at most, mainly cabinets with 4 to 8 kg,s, use recip comp set up at present which is o/k but you get oil problems and accumilator frosting and blocking up mainley in this wheather,could do with a larger oiless type but dont know who does them, push pull is not realy practical on this type of work,we use a multi hose set up and do 8 at a time, any info apreceated.
    Apr 2006
    Northern England
    Re: Recovery Units
    Would this one not be sufficient?
    http://www.ryanairconspares.com/inde...recovery-syste
    Aug 2004
    Holland
    55
    Re: Recovery Units
    Quote Originally Posted by racs
    We have got these s**t things.
    if pumping down liquid you will have to stay with the THING to wiggle the valve since to much liquid will kill it, once you reach gas state you will need coffee a whole lot of coffee.
    O sometimes they do stop because the high pressure switch tripped, in that case you will need to take the whole unit apart to reset it.
    Big advantage it is small and very light.
    Victor
    Jun 2001
    N.Ireland
    1,630
    Re: Recovery Units
    I use the american Promax units, the only problem I have is some theiving sh1t stole our last one and we had to buy a new one.
    Shifts a lot more than any other I can name on any mode.
    Kind Regards Andy.
    PS if it breaks you can get all the bits to rebuild yourself, or have it rebuilt by the manufacturer.
    Kind Regards Andy
    Apr 2006
    Northern England
    Re: Recovery Units
    Quote Originally Posted by coolman
    Victor
    The compressor is also protected by an automatic low pressure cut-off switch that shuts off the unit once the recovery is complete. This AUTO SHUT-OFF feature eliminates the risk of compressor failure and reduces the user's need to monitor the entire recovery system. ??
    Oct 2001
    Nottingham UK
    5,667
    Re: Recovery Units
    RACS
    You sound like a salesman not an engineer?
    Whats your background?
    I've had one of these units and in the field they just don't add up to the advertisements. What make of recovery unit do you prefer?
    Apr 2006
    Northern England
    Re: Recovery Units
    Quote Originally Posted by frank
    RACS
    Morning Frank, yes you could call me a salesman but i was only trying to help, been in the industry for close to twenty years now on the distribution side. Just placed an advert on the site and thought i would back myself up with some input. I also sell the manifold sets with Full 3/8" bore all the way through the block increasing flow over the standard block designs.
    Oct 2001
    Nottingham UK
    5,667
    Re: Recovery Units
    Hi RACS
    Yes I noticed that we now have a paid advert on the forum and it seems like you have a broad range of goodies for sale. I might even send you an enquiry
    On the forum though the Boss doesn't go too well on advertising so it might be an idea to limit the sales links.
    Hope you can have some technical input though.
    Feb 2006
    derbyshire
    610
    Re: Recovery Units
    theese small oil less units are only good for chucking in the van and hauling up a ladder for small unit charges and engineers with loads of time, i would love one that does what it says it does, i have a yellow jacket for little jobs,thats not too bad but use the polar pump units for the biger jobs, they do work but are quite large,just thought someone might cater for us lot who have to get 50kg plus out quickly.
    Mar 2005
    Birmingham U.K.
    70
    54
    Re: Recovery Units
    Re: Recovery Units
    Have been using a 110v CR600 oil less recovery unit from CPS for the last 3 years without any problems but today it decides to seize up!
    Only recovering R22 gas at the time so no Liquid hitting the pump.
    I made a few phone calls to other engineers and they told me that they have had similar problems with the CR600 unit with the circuit breaker tripping (oil less compressor seizing)
    Anyone else had problems with this recovery unit?
    It cost me about £700 to buy and I understand that the wholesaler send them back to Holland for repair so for me it will not be a cheap repair.
    Any recommendation for a good recovery unit ?
    regards Bob
    Sep 2005
    Australia
    33
    Re: Recovery Units
    Quote Originally Posted by bobjob
    Re: Recovery Units
    Have been using a 110v CR600 oil less recovery unit from CPS for the last 3 years without any problems but today it decides to seize up!..........................................(oil less compressor seizing)
    Hi!
    we use 1 of cr600e (e for 220V) and we can't kill it! (vapour, liquid, hammering noise, sometimes a little oil, hammering noise, and so on....my colleauges try hard! It has survived one of the greatest "fun" for a recov unit: liquid refrigerant+oil+water mix )
    Not too long ago we bought 2 of cr700e. They told us it's better beacuse you can overhaul it in a few hours. One of them seized during the warranty period but nobody knows why. We got a new one and it works well.
  1. What units you'll see in your country?
    By nova in forum Transport
    Last Post: 07-11-2010, 02:31 PM
  2. Recovery and vacuum equipment
    By Larry2 in forum Fundamentals
    Last Post: 19-07-2006, 12:16 AM
  3. Mitsibishi VRV System 8 out of 10 units work
    By moondawn in forum Air Conditioning
    Last Post: 29-09-2005, 11:02 PM
  4. Highcool split air con units
    By iceman007 in forum Air Conditioning
    Last Post: 31-05-2005, 12:31 PM
  5. AC units as cooling units
    By Peter_1 in forum Commercial
    Last Post: 18-03-2005, 06:42 AM
