    Jul 2005
    INDIA
    14
    5h Main Bearing Removal And Inserts
    What Is The Procedure Of Removing And Inserting The Main And Pumpend Bearings For 5h46 Carlyle Compressor . Pls Explain In Detail, Better If Thereis Any Picture Of Procedure....and What Tool Is Used For Removal & Inserting Bearing, Where It Is Available, Also Any Website Too See It...pls Help.........
    Jun 2001
    N.Ireland
    1,630
    Re: 5h Main Bearing Removal And Inserts
    Quote Originally Posted by altaf22m
    treaded rod, a bit of pipe to fit over the bearing and a flat plate will suffice.This will also enable you to refit the bearing.
    Info possibly on the carrier web site.
    Kind Regards. Andy
  1. 5h Main Bearing Removal And Inserts
    By altaf22m in forum Commercial
    Last Post: 07-03-2006, 04:54 AM
