Thread: Clivet heat pump wsan-ee121
10-11-2013, 02:07 PM #1
Dear all, I have recently procured clivet heat pump ...
The electrician has prepared all electric connections based on the drawings. I have a problem that the unit works on cooling mode only, doesn't switch to heating.
the kep pad is also connected to the heat pump, however it doesn't receive/read signals from the heat pump.
Can you please assist me on this?
10-11-2013, 02:27 PM #2
Re: Clivet heat pump wsan-ee121
http://www.delta-temp.be/bestanden/e...tie_engels.pdf
check the drawing is correct, comfirm connections
10-11-2013, 04:32 PM #3
Thanks we used this one ...but we still have the problem. The electrical connections are identical. The hear pumps works on cooling on its own. The key pad on/off button doesnt respond...nit even heating!
17-11-2013, 09:50 AM #4
does the controller show the snowflake- green light when you select heat mode?- it says that some settings rew enabling on comissioning- i'll keep hunting
17-11-2013, 09:54 AM #5
page 18 mentions a service keypad
11-02-2014, 05:01 PM #6
We became a Clivet dealer for a while at Denco, many moons ago.......
The controller was a little weird, in fact, it was aresey-versey
To select cooling, you had to select the SUN symbol to denote that it was hot
If you wanted to select heating you had to select the SNOWFLAKE sysmbol to indicate you were cold.
Just a whimsical thought, but I wonder if this helps you at all?
