Results 1 to 2 of 2
10-11-2013, 09:08 AM #1
Design of ammonia vapour absorption refrigeration
Guyz i had chosen a project of vapour absorption refrigeration which works using the waste heat of IC engine.I m a final year mechanical engineering student,but hav no experience of such system.I have to use ammonia water pair for this vapour absorption system..problem is how to select the size of standard pipes made out of C-steel.Also i need calculations steps for designing evaporator,generator,rectifier,condensor,etc...plz helpp me.
10-11-2013, 06:02 PM #2
Re: Design of ammonia vapour absorption refrigeration
If we give you all of the answers then you will not have learnt a lot.
It is your choice of project.Brian - Newton Abbot, Devon, UK
