    Apr 2012
    Iraq
    35
    623
    370 vac vs 440 vac capacitors ?
    What is the difference between 370 vac and 440 vac capacitors
    11,025
    Re: 370 vac vs 440 vac capacitors ?
    70Vac is the simple answer.
    Both are rated for a particular duty, the smaller one will not do the job of the larger one.
    Aug 2013
    Portugal
    It's the maximum Voltage that they can handle in Alternative Current.
    VAC=Volts Alternative Current
    Apr 2008
    Canada
    253
    4
    The voltage rating is only the maximum voltage that a capacitor should be exposed to, not the voltage that the capacitor will charge up to. A capacitor will only charge to a specific voltage level if fed that level of voltage. It is normally recommended to give a good amount of room when choosing the voltage rating of a capacitor. Meaning, if you want a capacitor to hold 25 volts, don't choose exactly a 25 volt-rated capacitor. Leave some room for a safety margin just in case the power supply voltage ever increased due to any reasons.
    See links for source info:
    http://www.learningaboutelectronics....capacitor-mean
    http://www.achrnews.com/articles/cap...se-compressors
    moideen's Avatar
    Apr 2008
    u.a.e
    49
    412
    As I know voltage rating is very important. When replace a capacitor, never down the voltage. Use same voltage or higher than the existing.
    Apr 2012
    Iraq
    35
    623
    Quote Originally Posted by passandscore View Post
    thank u very well
    that was very useful
