    Mar 2009
    29
    Radford Scroll Pack - HP switch?
    Can't find a HP cut-off on a Radford HT scroll pack (R404a). Any ideas if it's placed somewhere unusual? Or is it possible they were installed without a mechanical HP switch? It was installed in '97.
    Apr 2008
    Canada
    253
    4
    Re: Radford Scroll Pack - HP switch?
    Check the electrical schematic. Perhaps you're correct! I assume you followed the highside piping and checked the control circuit?
    Mar 2009
    29
    Yes mate, checked everywhere around the pack. All the pressure switches on the high side just controlled the condenser backup.
    I thought, or perhaps assumed, it were a legal requirement to have a mechanical HP cut off on systems this size?
    Sep 2013
    uk
    hp setting sometimes controlled by elm/rdm controller via pressure transducer,forcing pack into standby mode.
    you will find compressors are fitted with fixed hp switches
