Thread: pump fundamentals
04-03-2006, 10:52 AM #1
pump fundamentals
Can anyone give me some info on calculating flow rate of water on chilled water systems using the pressure drop across the pipe and the pump.
What should the minimum pressure on the pump inlet be?
What ratio would we get from high to low etc?
04-03-2006, 07:17 PM #2
Re: pump fundamentals
Inlet pressure should not be below atmospheric.
You really need the pump curve from the manufacturer to be able to establish the flow rate through the pump.Last edited by Brian_UK; 04-03-2006 at 07:17 PM. Reason: Spelling... again !!
liquid ammonia pump calvitation
By Kathleen in forum Trouble ShootingReplies: 23Last Post: 20-05-2011, 02:18 AM -
frostles heat pump
Rebuild air2air heat pump
By stalker in forum Technical SpeculationsReplies: 3Last Post: 02-11-2006, 10:10 AM -
New pump
By Peter_1 in forum Air ConditioningReplies: 1Last Post: 13-12-2003, 06:19 PM -
System Pump Down
By Brian_UK in forum Technical SpeculationsReplies: 16Last Post: 25-10-2001, 10:39 PM
