Results 1 to 2 of 2
    Jan 2006
    31
    pump fundamentals
    Can anyone give me some info on calculating flow rate of water on chilled water systems using the pressure drop across the pipe and the pump.
    What should the minimum pressure on the pump inlet be?
    What ratio would we get from high to low etc?
    11,025
    Re: pump fundamentals
    Inlet pressure should not be below atmospheric.
    You really need the pump curve from the manufacturer to be able to establish the flow rate through the pump.
  1. liquid ammonia pump calvitation
    By Kathleen in forum Trouble Shooting
    Last Post: 20-05-2011, 02:18 AM
  2. frostles heat pump
  3. Rebuild air2air heat pump
    By stalker in forum Technical Speculations
    Last Post: 02-11-2006, 10:10 AM
  4. New pump
    By Peter_1 in forum Air Conditioning
    Last Post: 13-12-2003, 06:19 PM
  5. System Pump Down
    By Brian_UK in forum Technical Speculations
    Last Post: 25-10-2001, 10:39 PM
