    Nov 2013
    South Africa
    2
    Secondary Glycol leak
    Hello All
    What an awesome site.
    I have a secondary glycol system in a supermarket that has a small leak. We are unable to trace the leak as the glycol is transparent, is there any way of adding some sort of dye into the system?
    5,668
    Re: Secondary Glycol leak
    Hello Terry and welcome to the forum.
    Have a look here for food grade dyes which can be added to your water/glycol circuit.
    They have a distributor in Johannesburg
    Mar 2010
    usa
    120
    You can also pull samples of the condensate drain water and put it under a Refractometer. This way you can find the circuit that is leaking, then go case to case.
    Good Luck.
    hookster's Avatar
    Apr 2007
    Hampshire
    438
    32
    Expensive stuff that Frank
    Especially if its a large system, chuck in some drain tracing dye and you will find it.
    Nov 2013
    South Africa
    2
    We have managed to find the leak...yeah!
    I will be looking into purchasing dye as the system is large and I wouldn't want to run around as before.
    Thanks for all the input
