Results 1 to 9 of 9
    Jan 2006
    Adelaide , Australia
    192
    Thumbs down I hate gas leaks !!
    Anyone got a surefire way to absolutely find any leak in a system . I am SICK of it !
    60% of the time it works everytime.
    Aug 2012
    Russian Federation
    Question Re: I hate gas leaks !!
    Quote Originally Posted by Toolman View Post
    Hi, Toolman.
    what type of refrigerant ?
    Feb 2009
    telford
    2,092
    33
    drop it in a swimming pool! tek mate got three of them soap is the best to pinpoint but the tekmate will find the region.
    Oct 2007
    manchester
    5,639
    45
    spectroline glo stick- had a mitsi 3kw h pump 3 others had fixed- leaky flares and schraeder cores- each repair only lasted 4 mth- glostick found lines on 4way valve chaffed- everyone else just used nitro and leak spray- go tec -
    Aug 2007
    Adelaide Australia
    70
    562
    Hi Toolman
    The Spectroline dye is pretty good but you need to be able to get the lamp in, can be a bit hard on a small system. We have a Spectroline system, electronic and an ultrasonic detector as well but they have their limitations.
    Big Blue, Bubble Up, Snoop, etc is pretty good but sometimes hard to get it to where you want it.
    Unfortunately I don't think there is any surefire way using a combination is probably the best.
    regards
    Paul
    Apr 2008
    Canada
    253
    4
    Patience! That is the only sure fire way. We all use roughly the same methods / techniques and eventually the leak shows itself. You could always work on ammonia systems! You will never have a problem locating the leak then.
    Jun 2011
    Australia
    44
    336
    21
    Yeah stick the smelly stuff in it. When your nose burns you got a leak - when your balls burn you got a big leak..
    Jan 2006
    192
    Talking Re: I hate gas leaks !!
    Quote Originally Posted by HVACRsaurus View Post
    Thats pretty funny , maybe I can make a shandy add a little ammonia .
    Jan 2006
    192
    OK well I still hate them , thanks for the suggestions everyone .
    I've been around long enough to know & use all the tricks , the old soapy water in a spray bottle is good .
    BUT when you cant get to see a spot and you know there something there I use this ... http://superiorsignal.com/superior-accutrak
    , it was expensive to buy but has paid for itself many times over by preventing callbacks.
    I have a video of it working well , but cant work out how to post it !! Stay tuned
