21-10-2013, 12:20 AM #1
question regarding Sporlan Y825-2 control valve in oil supply system paralle rackl
Good evening to everyone. I am looking for any kind of literature regarding a Sporlan manufactured valve which has a label on it reading Y825-2. I havenīt found anything in the sporlan website.
This valve seems to control de oil flow from the separator/reservoir to the mechanical oil level controls at each compressor. I am confronting a low oil level situation in a R-404 low temp rack system including 9 compressors, and the only adjustable device in the entire oil supply system is this valve (oil level controls are non-adjustable). The oil separator seems to be working properly, keeping an oil level well above the bottom sightglass. Oil system filter is brand new. I guess this valve must be a pressure reducing valve, but i have no clue about its adjustment. If you know of any site with any information on this kind of valve, please let me know. Best regards.
21-10-2013, 02:47 AM #2
Re: question regarding Sporlan Y825-2 control valve in oil supply system paralle rack
Hello
I am guessing the Rack is a Hussman Rack. The adjustment for this valve is under the bottom cap. CW = increased differential.
21-10-2013, 07:21 PM #3
Yes a specific model for Hussman.
Nearest is the Y1236C, look at document 110-10 here...
http://sporlanonline.com/literature-...ontrol-system/
Be aware that there is a safety warning on some early versions of your valve...
69.41.183.10/documents/Bottom%20Cap%20Recall.pdfBrian - Newton Abbot, Devon, UK
06-11-2013, 03:44 PM #4
