19-10-2013, 10:09 PM #1
Interface betweeb DAIKIN VRV and Home Automation?
Hi everybody,
I m trying to integrate the Daikin VRV system to the home automation, I m using bticino with SCS protocol. Is there any interface between D3net and SCS? or D3net and KNX? I found Zennio that can convert between D3nt and KNX, but should be installed one interface for each A/C unit. I m looking for only one interface that can be installed between the SCS bus and D3net bus.
Thanks a lot
20-10-2013, 02:11 AM #2
Re: Interface betweeb DAIKIN VRV and Home Automation?
Will this do what you want done?
http://coolautomation.com/products/c...0d-daikin-vrv/
20-10-2013, 08:34 AM #3
mchild. thank you very much for your reply.
Yeah this may work, and I think I have to try it. I just found a tutorial that explain how to use coolmaster1000D betweeb bticino and Daikin:
http://www.myopen-legrandgroup.com/c...CoolMaster.pdf
this internface will convert Daikin protocol to Ethernet so will be able to communicate with the bticino switch. This may be a solution, but first I want to try searching for a direct interface between D3net and SCS protocol, if you know such interface or if it even exists.
21-10-2013, 02:14 PM #4
Did you look at the other products on the Coolautomation.com site? They have a number of products.
