Thread: R744 Supermarket Rack
03-03-2006, 09:56 AM #1
Hi guys, haven't been to RE in a while, nice to see some of the same threads STILL going
Thought I might show some fotos of an R744 (Co2) rack running in a supermarket. Store load is split over 2 cascade systems (R744/R507). Each R744 rack has 2 comps for the LT load, liquid recirc is used for MT&HT loads. 2 x H/Xchs as cond for R744/R507 evap and a normal 4 comp rack as hi stage. Hi stage is water cooled, closed loop with Guntner hybrid coolers used.
LP on R744 runs around 1400 kpa (-28ish SST), vessel kept at 2400 kpa (-11ish SCT), R507 rack runs around -15 SST to keep vessel -10 to -11 SCT. Copper pipe used for all pipe runs except larger dia. rack piping, largest size is 5/8" on shopfloor.
Sorry fotos are pretty avg, only had a camera fone, will try to get better res. shots.
03-03-2006, 10:59 AM #2
Re: R744 Supermarket Rack
good to se you back - was re-reading the au thread and I did wonder where you'd got
cheers
richard
04-03-2006, 12:05 AM #3
Hi 750! How much R507 is in your system?
04-03-2006, 03:18 AM #4
Thanks for posting the very interesting pictures. I for one would be very interested to find out more information about this system.
27-07-2006, 11:22 PM #5
Hi 750,fficeffice" />
Thanks for the interesting Co2 rack pix… and for sharing your nice “moustache” with us… just watch out for liquid flooding! ;o)>>
28-07-2006, 03:32 AM #6
I wasn't allowed photos, but just got back from a CO2 secondary refrigerant startup in a Sam's Club. I noted that there was about 1,100 lbs of CO2 in the A rack, so I would expect the same in the other machine, more or less. At any rate, an exposure of leakage under $2,000.00.
They have a separate generator with a backup compressor to keep the pressures below 500 psig in the event of a power failure. My guess is the refrigerant charge is around 1,000 lbs of R404A.
I see much sense in using secondary refrigerants such as glycol and CO2, as we confine the piping, exposure, and voume of gasses that perhaps contribute to global warming.
Maintenance of supermarket equipment
By ronsin1 in forum Supermarket RefrigerationReplies: 5Last Post: 03-05-2010, 03:41 AM -
Supermarket refrigeration training
By Deejey in forum Supermarket RefrigerationReplies: 5Last Post: 25-04-2006, 04:08 AM -
Maintaining Supermarket Refrigeration System
By Cofreth in forum Supermarket RefrigerationReplies: 17Last Post: 12-10-2005, 10:24 PM -
Servicing Supermarket Reach-in Freezers
By shogun7 in forum Supermarket RefrigerationReplies: 12Last Post: 30-04-2004, 12:05 AM -
By bersaga in forum Trouble ShootingReplies: 11Last Post: 01-12-2003, 03:40 PM
