Hybrid View
02-03-2006, 11:17 PM #1
How much run time should a compressor have?
Is there a prefered percentage of run time for a condensing unit in a 24 hour period?
Ken
03-03-2006, 04:11 AM #2
Re: How much run time should a compressor have?
The first question is related to method of defrost. If the system is medium temperature, then air defrost is probably used.
An air defrost cycle is longer than a positive defrost cycle such as electric or hot gas.
The total amount of time for the defrost periods is deducted from 24 hours. At design operating conditions, the balance of the 24 hours remaining (after deducting the defrost time) is what the capacity was probably based on.
03-03-2006, 05:56 AM #3
Depends on the system
minimum interval between two compressor starts
5 minutes
minimum compressor off time
2 minutes
minimum compressor on time
2 minutesThe primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
03-03-2006, 08:04 AM #4
hi matey, lot of qoutes for equipement i get are based on 18 hr running time,hope this helps,cheers.
04-03-2006, 07:55 AM #5
Originally Posted by kengineering
yes there is , it depends upon the outside temprature , as it varies up and down , the percentage of running also varies
the avarage of running is between 12 and 18 hour withen the 24 hour of the day
best wishes
afeef
04-03-2006, 09:38 AM #6
Originally Posted by afeef
Kind Regards. Andy
Pull-down time for residential unit
By TooLittleTimeZZ in forum DomesticReplies: 25Last Post: 18-03-2006, 01:27 PM -
Time delay for multi compressors
By iceman007 in forum Air ConditioningReplies: 5Last Post: 06-11-2004, 08:05 AM -
The time has come to leave home !
By eggs in forum Legal-Business-MarketingReplies: 1Last Post: 23-10-2004, 07:03 PM -
time lock in dunham-bush chiller?
By lin in forum Air ConditioningReplies: 5Last Post: 23-09-2003, 09:49 PM
