01-03-2006, 05:44 PM #1
cellar cooler with a/.c condenser
I know we've covered this before but now I've actually got to sort out one so I need a 3.5 kw a.c non inverter condenser on 407c
I don't seem to be able to find one as they're all 410a now and I don't fancy a fridge coil on 410a just yet!!
Anyone got an idea of who does a cheapie and is available?
Richard
01-03-2006, 06:28 PM #2
Re: cellar cooler with a/.c condenser
How about a Marstair MCU+30 ? or a Hicool HCA12C (£349)
How little do you want to spend?Brian - Newton Abbot, Devon, UK
01-03-2006, 06:55 PM #3
Brian
I don't want to use a 'proper' cellar cooler as the noise is a real factor as it's residential.
I will look at the high cool (which is Climate center isn't it?
Richard
01-03-2006, 07:49 PM #4
Hi Richard,
hycool is a York product made in Maylasia. Copeland scroll compressor. We use them on Unico units on the Thermosavesystems, back up heat and summer cooling.
Well engineered. Heat pump models, come out of the factory with the defrost probe fitted in the wrong spot, wrecking the fan blades, but you won,t have this problem in a cooling only unit.
Kind Regards. Andy
01-03-2006, 08:06 PM #5
Originally Posted by rbartlett
Daikin is cheap and nasty from what ive seen. B & Q do some real crap if thats too dear.Takes a licking, keeps on ticking.
01-03-2006, 10:56 PM #6
Richard, have you tried the new "J&E Hall" units or the "Quietis" range from Thermofrostcryo ?
I use both of them regularly and find them as quiet as or even quieter than AC condensing units.
They can both be run with 134a, 407c or 404a. Give them a try if you havn't already.
cheers
eggs
method to design air cooled condenser
By abbasi in forum New TechnologiesReplies: 4Last Post: 12-02-2008, 08:34 AM -
Optimum condenser fan speed
By star882 in forum FundamentalsReplies: 4Last Post: 27-02-2006, 01:50 AM -
Cellar cooler in the 'Vic
By shanes696 in forum CommercialReplies: 6Last Post: 19-12-2005, 10:43 PM -
Searle cellar cooler control problem
By iceman007 in forum ElectricalReplies: 6Last Post: 06-07-2004, 08:57 PM -
IMI Marstair Cellar Cooler
By Abe in forum Trouble ShootingReplies: 25Last Post: 20-03-2004, 02:03 PM
