Results 1 to 9 of 9
Thread: Daikin rqyq140py1
02-10-2013, 07:23 PM #1
Daikin rqyq140py1
Hi fellas ,, need a bit of help .. I'm going to a job tomorow , a daikin rqyq140py1 was going out on E3 .. The engineer checked hp sp2 all ok , switch not open circuit , checked hp s1ph transducer and Dc voltage ok and corresponds to Lp .. He has replaced main pcb .. But upon starting unit up it goes back into E3 again .. ??? Any knowledge would be grateful before I get to site .. Cheers
02-10-2013, 07:31 PM #2
Re: Daikin rqyq140py1
“E3” Outdoor Unit: Actuation of High Pressure Switch
Remote
Controller
Display
E3
Applicable
Models
RQYQ-PY1
RQEQ-PY1
Method of
Malfunction
Detection
Use the protection device circuit to detect continuity at the high pressure switch.
Malfunction
Decision
Conditions
Abnormality is detected when the contact of the high pressure protection switch opens.
(Reference) Operating pressure of high pressure switch
Operating pressure:4.0MPa
Reset pressure: 3.0MPa
Supposed
Causes
Actuation of outdoor unit high pressure switch
Defect of high pressure switch
Defect of outdoor unit main PCB (A1P)
Instantaneous power failure
Faulty high pressure sensor
02-10-2013, 07:32 PM #3
http://www.mediafire.com/download/16...ice_Manual.pdf
service manual
02-10-2013, 07:33 PM #4
Well the engineer put it down to Pcb after doing all the checks , which I'm told he's replaced but e3 still coming up
02-10-2013, 07:35 PM #5
stick a gauge on to moniter the actual pressure- digital gauges will show min/max pressures- also instantaneous power failure??- reset the power on the indoor ringmain and the outdoor power
03-10-2013, 08:38 PM #6
And watch for the outdoor fan switching from high speed to low speed when the compressor is full speed.
Symptoms of a dodgy ambient thermister.
03-10-2013, 09:30 PM #7
Well after checking most components , I found that it was an earth leakage .. Comp shot and down to earth .. God knows why it was flagging up an e3 fault .. But that's what it was
03-10-2013, 09:41 PM #8
03-10-2013, 09:54 PM #9
For sure ... Caput mate
