Results 1 to 2 of 2
    Feb 2006
    Greece Creta
    5
    noise inverter compressor
    Hi all
    I have a problem with a VRF Hitachi RAS-10 FS2 R-22. The compressor Inverter after 5 years operation without problems, began to do a hard noise. The cooling capacity was as good as the first time. I supplemented oil without however exists no improvement, therefore i replaced with a new.
    Τhe oil was clean in the old compressor without scrap of iron in.
    But after 3 months and the new one began again to make the same noise. A very hard noise. The total length of pipings is roughly 100 m, the outdoor unit is in same level and only 2 indoors units are more highly at 4 metres. The number of indoors are 10 capacity 0.8 Hp, 8.000 btu/h. Compressor amper, high presure, Hz, are normal.
    Does anybody know what is that bring on the problem?
    Stelios
    Feb 2005
    sliema
    52
    138
    Re: noise inverter compressor
    Stelios,
    Same happened to me on a Mitsubishi heavy industries vrv.replaced the inverter compressor due to noise problem.After 3 weeks,it went to earth!! Found also to make things worst the sealed pcb on the back panel and also a high wattage resistor of 8 ohms.I cannot understand this.This type of vrv houses an inverter comp and a normal one.
  1. Cool-Therm (UK) Bring you the oil less compressor...
    By almichieuk in forum New Technologies
    Last Post: 18-02-2005, 04:29 PM
  2. Compressor pumping efficiency
    Last Post: 25-02-2004, 10:50 PM
  3. One Half of a Part Wound Compressor Motor is Burnt
    By aygul in forum Trouble Shooting
    Last Post: 25-08-2003, 11:11 AM
  4. Compressor failure...... cause
    By herefishy in forum Technical Speculations
    Last Post: 06-12-2002, 12:15 AM
  5. Starting a compressor, and receiver questions.
    Last Post: 24-08-2002, 12:37 PM
