    Sep 2013
    1
    Beko Fridge Feezer Noise
    My new Beko CF5834APS frost-free fridge-freezer makes a gurgling noise in addition to the compressor hum. Is this normal? It continues for around 50 seconds after the compressor and fan turn off. Because it is a random noise it is more distracting than the low compressor hum. The fridge-freezer seems to be working fine and maintaining correct temperatures.
    I have posted the following youtube clip...
    youtube clip
    Split Croatia
    57
    6,151
    36
    Re: Beko Fridge Feezer Noise
    Mine is doing same noise. No solution to that.
    Mar 2006
    Lancashire
    1,859
    28
    Does the fridge/freezer get down to set point?
    Over the course of any refrigerator’s cooling cycle the refrigerant gas is compressed, changed to liquid, boiled or vaporized, changed back into a gas and is pumped through a network of tubes designed to keep the unit cold through the process of thermodynamics. Throughout these changes and processes the refrigerant can often make some noise as it travels through the tubes located on the backside or inside of your refrigerator. A common sound of this refrigerant moving and changing states is gurgling or bubbling sounds. These noises are completely normal and a part of the refrigeration process.
    Marc
