Results 1 to 2 of 2
    Apr 2001
    2,099
    27
    Restricted Heat Exchanger
    Cellar cooling system . Evaporator iced up, landlord tried to break off the ice with a screwdriver and wham, pierced a nice hole in a tube.
    Fitted new drier and started up the unit. System low pressure went into a deep vacuum. I thought , well there must be moisture , ice water ingress and expansion valve is frozen up, but after delivering some warmth to the valve system remained in deep vacuum. Then I noticed ice, frost on the liquid exit from the heat exchanger. I remember reading somewhere that these components are prone to damage. I bypassed the heat exchanger.
    How common is this problem and whats the cause?
    Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
    Apr 2001
    2,099
    27
    Hello Marc,
    This cellar has no system pump down, interconnected by thermostat. Therefore no solonoid valve either. Condensing Unit situated on a horizontal line approx 10 metres away. Condensing Unit Prestcold 1 hp unit. Liquid line 3/8" Low side 5/8"
    Probably sizes dont matter but Ive put them in just so you get picture. Heat exchanger located just before evaporator.
    I wonder what was happening in the system for this to happen. System is about ten years old, maybe a touch more. Anyway just glad I found the problem and sorted. Thx for your help Marc
    Abe
  1. frostles heat pump
  2. Heat exchanger company ACP
    By JKProSoft in forum Legal-Business-Marketing
    Last Post: 22-07-2006, 11:37 AM
  3. Liquid reciever w/spiral heat exchanger
    By Carlo Hansen in forum Fundamentals
    Last Post: 16-06-2006, 01:18 PM
  4. heat exchanger design
    Last Post: 13-03-2006, 09:57 AM
  5. R134a <-> liquid heat exchanger design
    Last Post: 10-05-2002, 08:36 AM
