Results 1 to 2 of 2
17-09-2013, 12:54 AM #1
Braemar spectrolink multizone fan speeds
Hi all,
I am wondering if there is anyway to manually adjust the fan speeds on these models? I have 2 SCC and the manual says it cant be done, are there any options which will allow me to do this? Last time I was here I was helped with my other homes unit and am wondering if there is anything similar that can be done ( changed some codes via the control unit) The fans really ramp up and are quite noisy but really do push out alot of heat/cold.
Is this how these systems work? To automatically go to the highest fan speed to cool/heat up the home as quickly as possible then shut off?
Cheers.
17-09-2013, 10:26 PM #2
Re: Braemar spectrolink multizone fan speeds
As you say, according to the manual there is no fan override with the multizone setup.
