Results 1 to 16 of 16
    Dec 2005
    222
    ECM evap motors running backwards after a power surge.?
    We've been using Wellington ECM fan motors for a while now with no issues. Now a customer calls a claims that if there is a power surge his meat case fans reverse themselves. Has anyone had issues of this nature with this type of fan? Is it even possible. Mfr. says no but Just putting it out there. Thanks, Ken
    Sep 2003
    ISRAEL
    72
    4,248
    Re: ECM evap motors running backwards after a power surge.?
    Are they DC?
    11,025
    Do they all reverse or just some of them?
    If just some then perhaps they are just not running but being spun by the airflow of the ones that are running.
    Dec 2005
    222
    Well thanks for the replies. let you know when i find some new evidence. Phones been quiet today. LOL.Ken
    Aug 2013
    Portugal
    Even so they should turn around in the same direction, not in reverse...
    I suppose they can run in reverse if someone changed some conections...
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, TERRENAS
    Quote Originally Posted by TERRENAS View Post
    You are quite sure?
    I'm
    Best regards, Josip
    Feb 2009
    telford
    2,092
    33
    not too up on electrics,but had a 3 phase cond motor do it my mate who is more up to speed said it was known as ghosting,way beyond me i just treat elctrickery with the utmost respect.
    hookster's Avatar
    hookster is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    438
    32
    Quote Originally Posted by cadwaladr View Post
    I was on the opinion as with the other posts about client issue but cadwaladr got me thinking about "ghosting" or stray voltage and with an ECM fan depending on wiring of course the possibility that the fan controller sees stray voltage via its PWM input which if it was earth leakage would be more negative to reference. I do not think it is impossible to commutate a synchronous motor in the reverse direction as manufacturer states.
    Maybe try improve earthing arrangment or voltage regulation to fan controller.
    Aug 2007
    Adelaide Australia
    70
    562
    Hi Terrenas
    Brian is correct.
    When there are multiple fans on and evap and one fails the others will suck air in through this fan (air will take path of least resistance) and because the airflow is reversed the direction of rotation of the fan will be reversed.
    This has caught out a lot of inexperienced people and will continue to do so i would suggest.
    Paul
    Split Croatia
    57
    6,151
    36
    Here is description from Welington:
    ECM Technology
    Types of electric motor differ largely in how they achieve the interaction of magnetic fields, and most importantly the field reversals, necessary to make the motor turn. Electronically commutated (ECM) motors are brushless DC motors where the direction of the electric current is switched using electronic controllers. As the switching of the current is technically known as "commutating”, brushless motors are also called “electronically commutated” motors.
    I would say yes, it is highly possible that power surge makes electronic circuitry to change direction of fan rotation.
    Split Croatia
    57
    6,151
    36
    Are they DC?
    Yes they are!
    Split Croatia
    57
    6,151
    36
    Second part:
    Jul 2013
    58
    11
    Try adding some capacitors to the power supply rails.
    Modern inverter drive ("ECM" or "brushless DC") motors are very sophisticated inside. Many modern implementations, such as Delta's Cindy Wu sensorless FOC (used mostly for cooling high performance computers), dispense with the resolver altogether and replace it with a single chip computer to derive the rotor position and hold the stator flux 90 electrical degrees ahead of the rotor, where the efficiency is the best.
    Split Croatia
    57
    6,151
    36
    Rotation Sensing
    The first time the Evergreen EM is powered up and receives a signal on
    one of the Low Voltage Signal terminals, it will perform a Rotation Sensing
    process. With this feature, the motor will automatically determine the proper
    operating direction of the blower wheel by running the motor for several
    seconds in each direction.
    Do not turn off the “High Voltage Power” or the “Low Voltage Signal inputs”
    to the motor until the motor continues to run in one direction. During Rotation
    Sensing, the motor will run in both directions, up to four times if necessary, to
    determine the proper operating direction. If the proper direction cannot be
    determined after the forth sequence, the motor will operate in the default
    direction of counter clock-wise (CCW).
    Once the motor continues to run in one direction, Rotation Sensing is complete
    and the feature is locked out. The motor will continue to start and run in this direction
    without performing Rotation Sensing even if the High Voltage Power is disconnected.
    If the final operating direction of the motor is not the proper direction for the
    blower wheel, go to the “Troubleshooting Guidelines” on page 14; “Wrong
    Rotation”.
    Page 11 here:
    http://www.mediafire.com/?l75am5wahwvjkqw
    Somerset
    69
    4,697
    Thanks Nike.
    Brilliant!
    May 2012
    59
    1,528
    36
    Rotation Sensing
    Snip
    Rotation”.
    Page 11 here:
    As usual excellent information.
    I'd up your reputation if I didn't have to share my Luuuuuve around
    Rob
