    Apr 2012
    qatar
    40
    2
    Exclamation rotory compressor gone under vaccum while working
    hai gents,
    i am attending one complaint of mitsubishi mr:slim air conditioning unit.after starting its suction gone in to vaccum.this compressor also new.
    moideen's Avatar
    moideen is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2008
    u.a.e
    49
    412
    23
    Re: rotory compressor gone under vaccum while working
    Quote Originally Posted by prijorobert View Post
    hai gents,
    Hi, prijrobert, welcome to re.First ensures the system has charged sufficient refrigerant. If there is no gas, it required leak test and related job. If it is normal, then check the blockage of refrigerant through the circuit such as liquid line drier and expansion valve, also check any service valves whether it is closed.
    Oct 2007
    manchester
    5,639
    45
    ask the company who fitted it if he had a vac pump??
    as moideen says- check standing pressure see if theres any gas in it, u need to determine if it was sufficiently charged and proove theres no leak on the system, finally if the strainer gauzes are blocked
    Sep 2013
    Turkey
    32
    9
    hai gents,
    As moideen said,check the circuit.İf circuit is old,%80 circuit is filled up with refrigerant oil.Please change your circuit with new one.
