Results 1 to 2 of 2
Thread: calculation
13-09-2013, 12:33 AM #1
calculation
hi all,
if i have boiler produce 5000kg/hr so what is suitable pump(m3/hr) for it ?
thanks
13-09-2013, 12:01 PM #2
Re: calculation
1kg of water = 1l. SI std. iirc.
So, 5000kg/hr = 5000l/hr = 1.389l/s (l/s is what I normally see pumps rated in)
For your requested flow in m^3/hr:
Max. Density of water is 1000kg/m^3, so your 5000kg = 5m^3 max.
Therefore if you select a pump capable of 5m^3/hr against whatever your head is, it should be able to shift your production.
Now:
Density of water @ 100*C = 958kg/m^3
So, if your 5000kg/hr of production is @ 100*C,
5m^3/hr x .0958 = 4.79m^/hr =1.331l/s.
Assuming there is a size difference in pumps for that flow rate, I'd stick with the larger pump & fit a VSD to get the exact flow rate - if costs etc. allow - as it'll be less stressed & therefore should last longer.
However, I don't do this stuff for my living (just looked the figures up, remembered some long ago engineering lessons & converted) & will be interested to see if anyone disagrees & why.
NB: I take no responsibility if you choose to implement the information provided & find I got it wrong.Last edited by FreezerGeezer; 13-09-2013 at 12:25 PM.
