    Feb 2006
    Estonia
    10
    Rebuild air2air heat pump
    I plan to use air2water heat pump for heating, but the problem is high price of these heat pumps.
    Can I use external part of air2air heat pump (Fujitsu AWY14LAZ, for exampe) and connect to it refrigerant2water plate heat exchanger (Alfa Laval AC30, for example).
    Is it possible?
    I can use controller of the internal part of the air2air pump, the thermistor have to be recalculated.
    Does anybody know, what are the normal coolant input and output temperatures for air2air hvac, when heating?
    Feb 2006
    Estonia
    10
    Re: Rebuild air2air heat pump
    My question, my answer - yes, it is possible and works fine. Tested.
    Dec 2004
    Weihai,China
    800
    It saves your cost?
    plate heat exchanger is not cheap,how do u cut the cost?
    thx
    LC
    Feb 2006
    Estonia
    10
    The price of the air2air pump was ca $2000 with installation, the price of the heat exchanger was ca $400, the prices of the air2water heat pumps are at last here $5500 and up.
  1. New Heat Pump Forum
    By Argus in forum Heat Pumps
    Last Post: 10-04-2010, 09:12 AM
  2. frostles heat pump
  3. Replies: 8
    Last Post: 24-02-2007, 05:17 PM
  4. Replies: 3
    Last Post: 06-11-2006, 05:04 AM
  5. heat pump capacity adjust
    Last Post: 14-02-2006, 07:32 AM
