    Nov 2007
    Australia
    13
    Glass Condensation
    I have a project that I'll be looking at in Aust. They have a block of home units that gets massive condensation on the inside of the glass and this leads to mould issues.
    Im thinking double glazing.
    This problem is surely not unique. What do other countries do where it is very cold outside and warm inside (due to heating) to stop condensation on external glass faces?
    Dec 2012
    Lebanon
    14
    Re: Glass Condensation
    You already said the solution...
    May 2012
    1,283
    29
    Quote Originally Posted by Futsal1st View Post
    Just be aware that if the property is so damp that condensation forms on the window,
    the property will contain the same amount of moisture with the double glazing
    and if there are any cold spots on the walls, floor or ceiling then condensation
    will form there.
    Double glazing is good but you still need to refresh the air in the building.
    Maybe consider heat recovery, combined with double glazing and possibly
    de-humidification.
    Rob
