    Dec 2005
    Zagreb
    190
    Question DT of water heat excanger
    Why all chiller manufacturer vants 5 to 7 C DT.Would it be so bad to have 2 to 3 C DT?
    Q = m c DT in boath case.When changing DT ,m rises so Q is the same.I know I miss something can some of you open my eyes.
    Best regards,
    Renato
    Jun 2001
    N.Ireland
    1,630
    Re: DT of water heat excanger
    Renato
    Larger td means a smaller evaporator, cheaper solution.
    The dt you are refering to is the difference between the fluid on and off the chiller temperature. This relates to the design of the air side heat exchanger (air handling unit) or the process side heat exchanger. Most designs refer to a 6 to 10 td on the airside, again to keep the coil size down and the cost of the airside haet exchanger.
    Kind Regards. Andy
    Feb 2006
    Mauritius
    22
    Renato,
    As Andy said, if you go down on dt, the 'm' - flow rate of liquid through the evaporator - increases, hence the bigger evaporator size. But this means also a bigger evaporator pump, increasing your investment/initial cost. Now, with a bigger pump your running cost will be also higher.
    So, you lose on both initial and running cost.
  1. cold river water
    By eftimios in forum Fundamentals
    Last Post: 09-11-2008, 06:37 PM
  2. Refrigerant to water heat exchangers
    By sunwind in forum Technical Discussions
    Last Post: 24-06-2008, 01:40 PM
  3. frostles heat pump
  4. VFD heat pump water heater?
    By star882 in forum New Technologies
    Last Post: 23-05-2006, 08:36 PM
  5. Mcquay water source heat pump
    By bernie in forum Air Conditioning
    Last Post: 10-02-2003, 01:53 AM
