    Nov 2004
    perth australia
    77
    14
    poly glycol low temp systems auto air vents.
    can anyone inform me if they have experence in automatic air vent valves for low temp glycol systems. thanks.
    Apr 2008
    Canada
    253
    4
    21
    Re: poly glycol low temp systems auto air vents.
    I have used the following products with success.
    https://customer.honeywell.com/en-US...tpath=1.2.26.1
    11,024
    As Pass and score suggests they all work.
    I would also suggest that you include a sensible length of branch pipe from the pipe being vented to allow any microbubbles to accumulate before they enter the AAV.
    Dec 2010
    Toronto, Canada
    1,454
    Try and use ones with stainless steel bellows and Viton seals. We have this problem in the solar industry all the time. Caleffi makes a good one as does Spirovent (I believe).
    Apr 2009
    israel
    778
    we use these and they are great !
    http://www.arivalves.com/products/industry/item/s-050-segev-automatic-air-valve
    only the plastic ones ! both on polyglycol systems and regular water systems
    good luck
    THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
