    Mar 2008
    28
    63
    11
    Testing with a Megger
    Hi Guys,
    I've been told a few different ways to do this by the blokes I work with.
    Can anyone confirm to me though the correct and safe way to test single and three phase motors using a megger. Either balance testing (which I believe is using the ohms setting) or insulation testing (using the volts setting).
    Many thanks in advance,
    Bash
    Jun 2011
    Australia
    38
    315
    Re: Testing with a Megger
    To megger test a 3-phase motor with a 1000volt megger tester:
    Testing to earth
    a) Switch off the circuit breaker.
    b) Connect black megger test probe to earth. Check for ground continuity, to a terminal box bolt (this is check for good ground connection)
    c) With black probe still connected to ground, connect the red test probe to a motor terminal. Push test button. Insulation resistance should indicate 1 meg-ohm or more.
    d) Repeat test on remaining motor terminals
    Testing between windings
    e) Disconnect all line connections & remove bridging links.
    f) Identify the individual winings
    g) Connect black probe to one winding, test with red probe to other windings. Again, insulation resistance should indicate 1 meg-ohm or more.
    Oct 2007
    manchester
    44
    5,707
    g- ur only testing resistance so the reading will be in ohms- in 3 phase they should be equal in a single phase compressor they will be different according to start and run windings
    Sep 2003
    ISRAEL
    66
    4,173
    40
    An important note, never ever megger a compressor when it is under vacuum!!
    Oct 2012
    Russia
    37
    391
    12
    That can happen?
    Oct 2007
    manchester
    44
    5,707
    Split Croatia
    52
    6,108
    31
