Thread: cross-charge expansion valve
20-08-2013, 12:51 PM #1
Hello
i have stumbled upen the term cross-charge expansion valve, could someone explain this to me?
regards
20-08-2013, 01:21 PM #2
Re: cross-charge expansion valve
In the bulb there is a refrigerant that is used to open and close the valves diaphragm
dependent on the amount of pressure inside it at the time.
The refrigerant in the bulb tends to be the same as the refrigerant inside the system.
If for reasons of control they put a different refrigerant in the bulb to that used inside
the system, they call this a cross charge.........
Refrigerants react to certain temps and pressures so if we want something to react
differently we put a different refrigerant in........ Cross charged.
Rob
20-08-2013, 02:03 PM #3
Well that is actual quite simple then, thanks for the fast answer !
20-08-2013, 04:02 PM #4
20-09-2013, 10:56 AM #5
Go through sporlan selection catalogue or book by roy j dosat..........principles of rerigeration
d d koranne
