Results 1 to 10 of 10
    mr cool (aus)'s Avatar
    mr cool (aus) Guest
    bit of a pickle.. any ideas??
    hi all
    as my work is based on transport refrigeration a client has asked for:
    a truck and tralier (insulated approx 6 meters in length each) that carries chicks on occasions or chick eggs.
    for the eggs the client needs 15 degrees celcius with no fresh air and for the live chicks 26 degrees celcuis is required moving 3 litres of air per minute. it will be either carring one or the other not both at the same time. any ideas on the best way to arrange this would be fantastic. thankyou in advance
    Feb 2006
    derbyshire
    610
    Re: bit of a pickle.. any ideas??
    hi,is it not just one of your transport units with a duct system and extract with a fan unit at the said volume.when i worked for thermo king many moons ago there were containers using a similar spec,cant for the life think what for now.
    mr cool (aus) Guest
    yes, but the 1 unit will have to perform all the explained tasks..would a pre-cooler be a good idea
    Mar 2006
    canada
    Chick haulers are a touchy thing. I have worked on a couple that use a roof top unit to cool, power supplied by a Cummins GEnset, and glycol to heat. This is a real mess because none of these things were built to be bouncing down the road. Broken pipes and freezing pipes seem to be the norm. Even with all the problems it seems to get the job done. not nice to work on though and very expensive to build and repair.
    Reefermadness
    Mar 2006
    India
    80
    70
    Cool Re: bit of a pickle.. any ideas??
    Few points need clarification.
    1. Eggs comming to the truck will already be precooled and hence the load is only to meet the heat gain thru the insulated cabin.
    2. For chickn transport,the indirect evaporative cooling well do very well. One can have 100% fresh air if desired alternatvely the DX system designed for eggs can be used as an after cooler for the indirect /Direct evaporative cooler.
    Assumption is that the climate is suitable for indirect /Direct evaporative cooling.
    Advantages
    1. A Normal car airconditioner system run by the truck engine may do the job
    2.There is no need to have an additional engine to run the air conditioner.
    3.The IDEC system can run on the truck battery without a problem.
    Do let me know if you need more help
    Mar 2006
    India
    80
    70
    Advantages
    Do let me know if you need more help[/QUOTE]
    Mar 2006
    Merate (LC) - Italy
    2,549
    I would prefer hot chicks around here.
    Apr 2006
    U.K
    11
    Talking Re: bit of a pickle.. any ideas??
    Quote Originally Posted by mr cool (aus)
    hi all
    Please be carefull of this project. You will need fresh air as well as humidity control to a certain degree. I have seen this done on a number of occasions and you will need air filters as well to stop the feathers collecting on the evaporators. Let me know if you would like to see a desighn that i have seen used and seems to be working.
    Apr 2006
    Philippines
    11
    This is one of the trickiest things to handle. Some countries in Asia have experimented in using small truck units and bus units, to disastrous results. What I was told is that the key to this is the control of the exchange of fresh air from the outside of the body. I'll try to get more details on this from my friend who has worked on a similar project.
    May 2006
    Mexico
    10
    What`s up Bro? more than being any help 2 you, I`m actually asking for help, I`ve worked on stationary equipment for a few years but would like to learn about ref. trailers. Perhaps you want 2 sell some books or something, I already tried getting a course from thermoking and carrier, but they won`t do it for a solo tech like me. Thanks
  1. Need ideas !!!
    By zvikard in forum Technical Discussions
    Last Post: 17-08-2006, 08:34 PM
  2. Your opinions and ideas greatly appreciated for this project.
    By fridg in forum Technical Discussions
    Last Post: 04-12-2005, 09:19 AM
  3. Ideas To submit
    By Alt Concepts in forum New Technologies
    Last Post: 13-09-2005, 12:55 PM
