Thread: Verifying TXV capacity
16-08-2013, 06:34 AM #1
I ordered a 1/4 ton R22 TXV (actually two) and it had a sensing bulb just a little smaller than a C battery. Thinking I might have got the wrong item or it was mislabeled, I decided to open it up to take a look at the actual valve assembly. To my surprise, the orifice was just big enough to stick a piece of AWG22 wire in it. Is that about right for a 1/4 ton R22 TXV? (There is an inscription on the valve that says 1/4, but I wonder if it was mislabeled. I would hate to carefully put together the system only to find out that the valve is completely wrong!)
16-08-2013, 08:00 AM #2
Re: Verifying TXV capacity
What number is stamped on the orifice? 00 or 01?
16-08-2013, 02:16 PM #3
It's one of those:
http://www.ebay.com/itm/SPORLAN-IVE-...-/220813007346
16-08-2013, 05:13 PM #4
get a Danfoss TEX2 with orifice 00 and your'e done.
08-09-2013, 12:39 AM #5
As an update, I installed the valve and it worked great.
