Results 1 to 2 of 2
Thread: Daikin Ururu Sarara
14-08-2013, 09:07 PM #1
Daikin Ururu Sarara
Anyone ever come across an Ururu sarara daikin wall mount unit? Some real funky thing with a kind of transformers style indoor unit when you start it up! Anyhow, does anyone have any technical info on these units??? Thanks in advance.
Craigf
14-08-2013, 09:31 PM #2
Re: Daikin Ururu Sarara
fitted 6 of em- bear in mind if ur installin em- indoors are bulkier- theres a steam pipe to run with ur pipework- about 28mm dia factory its 7mtr long but u can get extensions- u aint gonna fit inoac 75/mini lime pump trunking on the bugger- due to steam pipe- fit a gravity drain- universal pumps like blu diamond,aspen perisaltics cannot cope with the moisture it removes as it cannot detect the td accross sensors- even though u fit them correctly- theres 2 lev's on indoor - and a sub condenser too- check the humidifer on top of the condenser aint smashed on delivery as u have to butcher the buggers to replace the housing- good units, still working
daikin ux1 were the dogs danglies- been out about7yr ,now replaced with emura- not fitted any of em yet
beware capacities to 2.8kw,4.2kw
http://www.mediafire.com/download/a7...e_f_series.pdf
service manual
