    Aug 2013
    Canada
    1
    Condenser THR on Economized Screw Package
    Hello,
    I can't seem to remember whether the condenser THR is based on the BHP and Refrigeration TR only in the case of an economized screw. Do I need to account for the economizer load and oil cooling load in the condenser THR as well? i.e I have 280 BHP/80 TR Capacity, plus 30 TR Economizer and 20 TR Oil cooling. Total THR is?
    Thanks,
    RE
    Sep 2008
    Canada
    811
    Re: Condenser THR on Economized Screw Package
    All these loads go to the condenser.
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, RefrigEng1
    Quote Originally Posted by RefrigEng1 View Post
    Hello,
    Thanks,
    RE
    you need to calculate condenser for all loads like ... power of electrical motor, refrigeration load, economizer load, oil cooling load in case of refrigerant oil cooler ... it is the only way to reject total heat back to the mother nature .... of course with some addition in capacity due to fouling factor ...
    of course if you have water oil cooler it is not added to condenser capacity ...
    read this, please
    http://www.achrnews.com/articles/siz...ive-condensers
    http://www.achrnews.com/articles/120127
    http://library.kfupm.edu.sa/ISI/2006/4-2006.pdf
    http://lms.i-know.com/pluginfile.php...%20Control.pdf
    https://www.ideals.illinois.edu/bits...9750/TR048.pdf
    Hope this is of some help to you ..
    Best regards, Josip
    Sep 2008
    Canada
    811
    If oil cooling water have separate water tank and cooling tower, oil cooling load should not be included. If common water tank used for oil cooling and for evaporative condensers, oil cooling load should be included.
Tags for this Thread
