Thread: Toshiba wallmounts
11-08-2013, 08:44 PM #1
Toshiba wallmounts
Just installed 2 wallmounts and a condenser at my local shop but can't remember how to make 1 the master and the other the slave.From previous installs I know I had to wire a hard wired controller and go into a settings menu then change letters/numbers.It allows only 1 unit to operate when the infa-red controller is used,the slave unit will do what the master does.Hope that made sense.
12-08-2013, 09:17 AM #2
Re: Toshiba wallmounts
As far as I can remember you drop connection 3 on the interconnecting cable only connecting 1&2 at the slave.
But that said, depends on the models.
Not mauled any Tosh gear in a while.
12-08-2013, 06:45 PM #3
model number?
13-08-2013, 08:33 AM #4
If this is a Twin system, as above but with both indoors (A+B wiring) connected to the hard wired controller.
I have only installed 1 Tosh twin with wall mounts before and used an RBC-AMT32 - You will get the infra red controller in the packaging of the wall mount regardless so don't just presume it will work without the hard wired because it probably won't. The RBC cost comes included with twin split.
I presume you have 2x SM562KRT + 1x SM1103AT or 2x SM802KRT + 1x SM1403AT?
15-08-2013, 06:31 PM #5
It's cool guys,Toshiba said no need to address through a hardwire controller,they address themselves on power up.Its only if sharing a bs box on a vrf system you have to alter the settings.
20-08-2013, 05:44 PM #6
Happy Ending
