11-08-2013, 01:05 PM #1
From Tekelek dial thermostat to programmable thermostat, how?
Hi there,
I've got a Tekelek 425 dial thermostat (low voltage) connecting to a Brivis Advance 44 evaporative cooler, and hope to switch to thermostat with terminals R, Y, G....etc.
There are 4 wires going from the evaporative cooler to the current thermostat, as shown in http://i.imgur.com/ceBUMdw.jpg
Blue wire connects to terminal named "0V"
Green wire connects to terminal named "Control 2"
Yellow wire connects to terminal named "Control 1"
Red wire connects to terminal named "5.6V"
Does anyone knows how these translate to terminals R/Y/G..etc?
11-08-2013, 02:16 PM #2
Re: From Tekelek dial thermostat to programmable thermostat, how?
y cooling signal
g fan
w heat
r power into controller
11-08-2013, 09:35 PM #3
How the four colors of the above mentioned wires fit?
11-08-2013, 10:01 PM #4
dont know- u need to check on the cooler for what colour wire connects to what terminal
found an install manual it its any help
click on the link below
http://www.mediafire.com/download/pq...ers_Manual.pdf
