Thread: Strange on
09-08-2013, 09:10 PM #1
Strange on
Hi Guys Got a capital cooling cabinet, had new evaporator, all rebuilt how it came apart, both evaporator fans run, with deck plate and air on grill removed, case runs down to temp lovely, fit the air on grill and deck plate as it should, no air flow from air off grills, temp goes up, lift the deck plate by 15mm cabinet works lovely. Now do the fans need a certain distance clear from obstruction, to allow blade to move air, i'm puzzled by this one. Any idea's ???? J.J.
Remember: 'ITS NOT HOW GOOD YOU ARE ITS HOW BAD YOU WANT IT'
12-08-2013, 09:16 PM #2
Re: Strange on
whats the model of the case
12-08-2013, 11:50 PM #3
Re: Strange on
Ive seen that from a replacement fan motor that was 1/2" taller the the OEM. The Fan Blade was almost hitting the bottom of the deck pan. I had to locate a motor the same height as the OEM. The return was getting choked. Sounds like you have possably have a similar situation.
14-08-2013, 10:41 PM #4
17-08-2013, 09:14 PM #5
Re: Strange on
sorry I`ve never seen that model,all the ones ive ever worked on had fans vertical at the back of the case
17-08-2013, 09:27 PM #6
Re: Strange on
http://www.mediafire.com/download/rj...usermanual.pdf
if its any help
17-08-2013, 10:26 PM #7
Re: Strange on
JJ
Sounds like fan deck is in at wrong angle or the fan blades are backwards?
alecMostly found in the southern part of this green and pleasant land.
