Results 1 to 14 of 14
Thread: Lenox package unit
08-08-2013, 05:36 PM #1
Lenox package unit
Hi all
I've been called in on a private job to look at a Lenox package unit which some one has fitted in above a ceiling in a shop , it a huge thing hanging up on rod. Should be on a roof . But not there for that. It's got AL fault on control . I cnt find a thing about AL fault , dose any one know what it is .
08-08-2013, 06:39 PM #2
Re: Lenox package unit
if its a packaged unit- check the unit - if its an l box, theres a eng friendly pcb,if its a linea unit u need a kp02 controller to reset fault codes
what controller is it?
08-08-2013, 07:18 PM #3
image.jpgYeah it's a package unit it's around 8 years old , I've got a pic of control not sure how to put it up from my phone on to here
08-08-2013, 07:33 PM #4
Lennox controllers are always dirty!
08-08-2013, 07:42 PM #5
http://www.lennoxemeia.com/product/t...-fancoils/aria
cant find any manuals- but not much on it
08-08-2013, 07:51 PM #6
Ok thanks il take a look .ive tryed powering system down but fault is up at once.
09-08-2013, 07:05 AM #7
Hi all still can not find any fault for the AL fault I have which I have on control .all the faults I have found are all numbers. The system dose not run at all going to get a hove ceiling and have good look today . But any one know what this AL is ?
Thanks Paul a/c
09-08-2013, 01:17 PM #8
09-08-2013, 04:40 PM #9
Hi guy check above ceiling found covers off isolater has be break in on. Found 3 fuse out for main fan or condenser . Will pick up some new fuses test fan cables from contact to see if any thing is down to earth all ok there, someone has had a good play with it before .
09-08-2013, 05:05 PM #10
Hi Paul.
Have you any reference details for the package unit?
If it can be identified, I may be able to help further?
09-08-2013, 07:14 PM #11
For a start pull that Lennox bubble sticker off it , I'll be you a pound to a pinch of sh1t it say's Carel under it..
Usually...
AL alarm active it should give the actual code beneath
But depending on Lennox parameters could be generic code
Check the filters, probably icing up.
Stu
Then again page 39
http://www.hvacrinfo.com/Controllers/carel%20aria.pdfLast edited by stufus; 09-08-2013 at 07:22 PM. Reason: found some info
Tool's ? check ! Condom's ? check !
09-08-2013, 07:26 PM #12
Beat me to it Stu.
I found this link.
But I suspect yours is better?
Steve.
http://www.carel.com/carelcom/web/en...jsp?id_gamma=5
09-08-2013, 07:32 PM #13
We won't split hairs on this one Grizzly,
But knowing lennox it will probably be swings and roundabouts to reset the fooker.
Cheers pal
09-08-2013, 08:01 PM #14
Thanks for help guys I am back there on Monday with new fuse il get a pic of the details and see what happens when I but new fuse in
