    Apr 2013
    41
    HELP with: Evaporator and Condenser Surface Areas
    Hello,
    Domestic Refrigerators:
    Can someone please give me an evaporator and condenser surface area ratio please? Is the condenser usually larger in surface area than the evaporator?
    If you know the surface area for the evaporator and the condenser of any domestic sized refrigerator please can you pass on the information to me?
    A website link that showed all required dimensions to calculate surface area would also be great.
    Thank You
    Apr 2008
    Canada
    232
    4
    14
    Re: HELP with: Evaporator and Condenser Surface Areas
    Surface area? Not sure what value that will be to you?
    Basic mathematics: http://www.basic-mathematics.com/sur...lar-prism.html
    Apr 2013
    41
    Thanks passandscore for the joke, but I wanted a Value for the surface area of an 'Actual' Evaporator & Condenser, that someone on here would have worked with or studied. I am not having trouble with basic maths formulas (in this case).
    May 2012
    1,264
    28
    Not set in stone but for a rough rule of thumb
    the evap is always 2/3 that of the cond.
    It's not surface area but it's a start point.
    Rob
    Oct 2003
    56
    5,519
    28
    There are no rules for surface area, surface area has nothing to do with capacities. Volume should be a better value to compare but even then. What are your DT's, TE, TC, SH, SC...? All this will change the dimensions of your coil.
    Oct 2001
    Nottingham UK
    5,091
    42
    Surface areas are relevant to heat rejection/absorption in conjunction with temperature differences (dt) and duties.
    As with all calculations, you need to know 2 values to find the third. Just asking for a surface area ratio doesn't mean anything unless you know what the ratio is against.
    I'm back on the Pale
    moideen's Avatar
    moideen is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2008
    u.a.e
    42
    417
    There is no surface ratio between condenser and evaporator. Condenser will be sized after sizing the evaporator and compressor. Capacity of air cooled condenser is based on total heat of rejection (THR).THR is equal to the evaporator capacity plus heat of compression.
