    Apr 2013
    Total Heat Transfer Area: Vapour Compression Refrigeration System
    Good day to you,
    Does anyone out there know a good estimate or any real values for the total heat transfer area for the hot and cold sides of a domestic refrigeration system? i.e. the sum of the areas of the evaporator and the condenser.
    For the Evaporator:
    QL=UL.AL.(TL-T1)
    AL=heat transfer area of cold side (Low side)=????
    UL=overal heat trans. coefficient of cold side.=????
    QL=heat removed from cold side = 7.93 KW
    TL=refrigerator temp. = 3degs C + 273.15=276.12 Kelvin
    T1= Refrigerant evaporating temp. =0degs C + 273.15= 273.15 Kelvin
    I am trying to estimate this area so I can calculate the overal heat transfer coefficient which I need for other calculations. So far the outcome of estimating the area and finding the heat transfer coefficient based on it has not been realistic.
    If it helps:
    The aim of my project is to find the optimal heat transfer ratio between hot and cold side, there is theory on this which I am following, I just need some realistic values for area and heat transfer coefficient. I think it is more logical to estimate the area and find the h.t. coefficient based on that rather than the other way around.
    5,128
    42
    Re: Total Heat Transfer Area: Vapour Compression Refrigeration System
    I'm back on the Pale
    Apr 2013
    No, but I have read some of it now thank you.
