    Jun 2013
    China
    the compressor's cooling capacity difference from Bitzer selction software
    Hi,all
    The bitzer software, under 2-stage semi-herm. reciprating compressor, they have two cooling capacity data, Qo & Qo*, and they are different.
    What's the differnce between them? The Bitzer's paper catolog always list Q0*, so what's the fuction of Qo?
    Feb 2007
    2,477
    Re: the compressor's cooling capacity difference from Bitzer selction software
    Different standards of calculation by the look of things, the Qo* is calculated to EN 2900 standards.
    Jun 2013
    China
    Then what the standard for the Qo? what's Qo used for?
    Jiazi
    Oct 2003
    56
    5,519
    28
    The first is with the inputs you gave in and the second wit asterisk is calculated using the EN2900 standard, mostly other SH and SC than you specified in your inputs; EN2900 uses standard values.
    Jun 2013
    China
    Thank you all for your kindly input
    May 2006
    India
    68
    400
    12
    While selecting compressor maintainthe diffrence between evaporating & suction gas temp at about 20.
    Dd koranne
