Thread: Dry Rooms
    Aug 2013
    Canada
    52
    1
    Dry Rooms
    Hi everyone. This is my first post and new to this forum.
    I have a dry curing room I was servicing and the room won't come down to temperature.
    The room is 21 cubic meters and 3 - 5 deg. Set point
    The data on evap coil is 1.548 Frig/h 1,8 kw @ -12.5/+45 deg c (6139 Btu)
    2.236 Frig/h 2,6 kw @ -5/+40 deg c (8867 Btu)
    Suction pipe is 1/2" and liquid line is 3/8" and about 45' long going back to a rack system
    Tx valve - danfoss TES 5 with 0.5 orfice (I believe that is 3 ton) R404a
    The room can not hold temp and superheated is high with tx valve wide open. I believe suction line is undersized but will this cause this problem and what else can it be.
    Any help will be appreciated. Thank you
    Aug 2009
    New Zealand
    59
    2,556
    26
    Re: Dry Rooms
    Problem with liquid feed, suction line seems OK.
    Apr 2008
    Canada
    254
    4
    Re: Dry Rooms
    What are your operating pressures? Superheat and subcooling temperatures?
    Sep 2010
    india
    43
    Re: Dry Rooms
    u r used wrong suction line size
    u can use 5/8 or 3/4 size suction line for that 45 feet length
    change it
    lebanon
    130
    Re: Dry Rooms
    hi I see ur expansion is not correct and u need a little more kw
    Oct 2008
    newbury
    1,445
    37
