Results 1 to 2 of 2
    Jun 2013
    SINGAPROE
    4
    Ahu cooling capacity
    Dear One,
    How to find out the AHU Cooling capacity with the following parameters
    I have the air flow rate: 8500 cmh
    and the design condition is: out side 45deg and 90% RH
    Room 22deg and 50% RH
    Thanks..
    Mar 2010
    Vietnam
    33
    Re: Ahu cooling capacity
    First U will need to find out the required fresh air raito .
