    Jul 2005
    55
    10
    Next control and monitoring systems
    Hi Guys anyone worked on the Next control and monitoring system, I guess its a similar system to the RDM, I have not been given any info or log in details yet so making it difficult to work on, I have two serve overs controlling lower than they are set to (although I cant get in to parameters to check) and one unit flashing pd of witch I'm assuming this is a probe fault. I have been told there will be a hand held reader sent to site for next visit to use, but could do with a little info before I get there
    Jan 2009
    58
    161
    Re: Next control and monitoring systems
    Hi Seacold,
    PM me your e-mail address and i'll send you what I have
    Regards,
    Mel.
    Mostly found nowadays at the sharp end of the stick!
    ireland
    1,450
    41
    PD might be pull down, the RDM units control to below setpoint by the differential, setpoint is cut in rather than cotout, but this is RDM.
    alec
