Results 1 to 2 of 2
Thread: Compressor terminal identifing
21-07-2013, 09:07 AM #1
How to identify Compressor terminal like common,ruining,staring.
21-07-2013, 09:24 AM #2
Re: Compressor terminal identifing
disconnect wires off pins- using a multi meter set to ohms- measure resistance accross pins- the highest reading is accross start and run pins, then the next highest reading is accross ur common and start - or usually on the compressor cover will show ur pin terminals
