Thread: sometimes... *pic*
sometimes... *pic*
all you can do is shake your head
Not the best picture, but what you are looking at is the cylinder head of a 2cyl Grasso... that thing you see above it, with the hole in it is the deck... about an inch over the cylinder head
a co-worker of mine had to cut a hole in the trawldeck to access it a few months back, glad it wasnt me
-Cheers-
Tycho
15-02-2006, 09:07 PM #2
Re: sometimes... *pic*
Hi Tyco
I have to say the picture of the Grasso made me laugh.
What good the hole would be is anybodys guess, especially as the linner and piston has to come out the top to change the small end bearings and the piston rings.
What were the installers thinking off
Kind Regards. Andy
16-02-2006, 05:39 AM #3
Originally Posted by Andy
cheers
richard
The tiny hole you see in the picture is made by the yard (for hanging pulleys)
you see two white lines above the compressor, thats where they cut the hole with a blowtorch, and welded it back in.
"who designed this?"-Cheers-
Tycho
17-02-2006, 03:49 PM #5
My first assignment as a 17 YO refrigeration "technician" was to help a senior Serviceman by the name of Frank Rodoni to overhaul a completely shelled-out York Y-53 12 cylinder. I put the long crankshaft in my service truck and drove to the ice skating rink, presenting myself for work.
Frank welcomed me to the brotherhood and told me to unload the crank. I did so. Upon turning around, there was Frank. He handed me a chisel and sledge hammer. I asked what it was for and he told me the first lesson for a engineer was to learn proper clearances for installation.
He pointed to an "X" on the wall and told me to chisel out that concrete block. He then explained that it was simply easier than wrestling the huge cast iron motor from the other direction on a the shaft-coupled compressor off the mounts. ....We had to pass the 7 foot long crankshaft through the hole in the wall to install it!
His second lesson taht day was even more memorable... I smelled ammonia for the first time.
17-02-2006, 05:07 PM #6
LOL
Almost perfect shortcut, of course in conjunction with that remarkable service tools
18-02-2006, 10:32 AM #7
Originally Posted by Mark C
I freind of mine asked me to take his "wee" brother for a few weeks experience.
The fellow was 16 or 17 years old and well over 6'.
We were servicing a SMC108S Sabroe recip it goes a bit like this.
Now watch yourself I am going to take the side cover of and there will be a bit of a smell. Yea ok was the reply.
The cover was off and so was the lad, straight to the plantroom door which opened in. He tried to push it out, nearly did too . When I caught him he was sitting outside eyes streaming, gasping for air.
I have to say it woke him up, he listened to me after that.
Kind Regards. Andy
