Results 1 to 15 of 15
    495
    21
    lennox r410a heat pump
    hi friends i have a problem with this chiller. This week its been very hot about 30c ambient temperature.got a call out to see why wasnt working.got site and found c1 fans not comming on and c2 empty of gas.the fan inverter wasnt sending any power to fans its a altiver 21.so by pass it and ran fans direct and it ran for 2.5 hours good. Brought temp from 36c to 14.8c and then the pressure unit its armstrong went out on fault and shut the chiller down on bms.refilled the pressure unit got pressure upto.0.9b and restart the chiller. It ran for 20 minutes and it went off again on pressure unit.found the bladder empty of pressure so pumped air into the bladder and fill it up with water again. But still shows fault on bms and chiller wont run. The chiller has it own electronic flow switch and customer has sontay pressure switches. The water flow is 2bar in and 1.5 bar out of evaporater.the chiller shows on service display is unit on. Enabled c1. Comps waiting flo. Switch on. Hp off lp on. Im stuck on what to do next.how to get it going or how to by pass bms. any help will be great ful
    Oct 2007
    manchester
    5,639
    45
    Re: lennox r410a heat pump
    http://www.mediafire.com/download/hi..._14_LENNOX.pdf
    has the expansion vessel bellows held at 1 bar or has it leaked back into system?
    495
    21
    Hi the xpansion vessels bellows pump upto 8 psi and unit water pressure upto 1.2 bar. But im going back tomorrow and try again. Is there any way to by pass these things to run the chiller for few seconds just to prove the chiller is ok
    Oct 2007
    manchester
    5,639
    45
    bms can be bypassed - usually its just a remote on/off signal and a common fault signal. check external wiring going into the chiller.
    check control panel for bms for chiller relay- maybe manually latch it to enable output
    pressurisation unit will only alarm on hi/low pressure and constant fill-leak prevention- as long as ur system is between 1-3 bar shouldnt be an issue
    495
    21
    Thankyou friend
    Oct 2007
    manchester
    5,639
    45
    does the chiller have a dc50 controller- because you would need a ds50 service tool to reset a major alarm- and also easier for reading alarm history and thermister values
    495
    21
    Yes it does have a ds 50 service controller and ive reset all alarms on it and when you check rhe comps it say comps wait.flow,state on
    Oct 2007
    manchester
    5,639
    45
    state on - signal for comp run- unless external safety devices holding it off- pressure switch/flow switch
    495
    21
    Im there tomorrow morning again and ill give an update to what has happen
    495
    21
    Hi install its the carel pco board that isnt sending signal. Got lennox comming out to replace soon.thankyou for your help friend
    Oct 2003
    5,630
    34
    Ghaz, your avatar is an opened Bitzer. Why you opened it? We have a similar machine with exploded oil filters in the compact screw.
    Oct 2003
    5,630
    34
    An it's also in a Lennox but on R407c
    495
    21
    Hi peter my picture is of an csh 85 bitzer i open it to change the oil seperater o ring and internal oil filter because the previously motor burnt on it
    Oct 2003
    5,630
    34
    Was the machine old and ran it a lot of hours? Did your rewind the motor?
    We have on a Lennox now in 4 years 5 burnt compressors
    495
    21
    Yes machine wasnt that old it was on r407c gas wirh water pumps built on chiller and 2 times pump fail and then on circuit 2 two compressors burn out and finaly the evaporater had burst it copper tubes and the chiller got scrapped
