Results 1 to 19 of 19
    Feb 2006
    10
    Help Please: R-12 or R-22
    I have received conflicting information by two local
    refrigerator repair shops. I have a very old Philco refrigerator probably made
    around 1950. It still works fine but is a low on ***** and needs some added.
    One repair shop said R-12 is what it needs, the other shop said
    R-22 is what it needs. I don't know who to believe?
    I have looked all around the compressor for a tag but
    haven't found anything. Any advice would be greatly appreciated.
    Thanks!
    Dec 2005
    South East England
    56
    155
    Re: Help Please: R-12 or R-22
    I'm guessing that a fridge of this vintage has got a belt-drive compressor? Firstly the fridge should be leak tested before putting any more gas in, it may just be leakage past the compressor shaft seal which was normal on open drive compressors back then. Also a complete fresh charge should be put in after evacuating the system with a vacuum pump & the filter drier changed also for long-term reliability. Is there not a tag anywhere else on the fridge giving details?
    It's more than likely R12, but as R12 is now out of use as it's a CFC, the alternative is R409a. Some fridges of that era used Sulphur Dioxide too, so you really need to find a tag.
    Noah had to leave the dinosaurs behind as they would've sunk the boat.
    Feb 2006
    10
    Thanks for taking the time to answer my post.
    I just finished looking around the compressor again and
    found one tag which gives the model/serial #:
    Philco Corp.
    Serial # 3091293
    Model: MRG
    Dec 2005
    South East England
    56
    155
    Sorry, can't glean any info from that & a search on the web doesn't show anything up. Are there any tags inside the fridge?
    1950 eh? Blimey I thought my 16 year old Indesit was doing well
    Feb 2006
    10
    I can't find any other tags at all. I don't see a belt on
    the compressor but that may not be what you mean.
    I have no knowledge about compressors.
    It could be late 40's to 1950. I know its approximate
    age because it was my grandfathers.
    Feb 2006
    10
    Hey... I took a few pictures of the fridge and compressor.
    Don't know if this will be of any help but can't hurt.
    I appreciate the help guys...
    Feb 2006
    10
    As you can see from the freezer pic it has a small ice
    ball in there. It just doesn't have enough juice to get
    cold. The fridge doesn't leak at all while the power is on.
    It has been running for several years without any problems.
    But my breaker flipped off while I was out of town and
    it did leak while the power was off. Its done that twice
    now, it only leaks when the power is off for extended
    periods of time. I am going to have that problem addressed
    when I decide which shop to take it to. But the two shops
    are telling me two different things, one says r12 the other
    r22. I am afraid if I pick the wrong shop they will destroy
    the compressor by putting in the wrong type *****.
    11,025
    Hey Philco, that's some kind of classic there, that's for sure !!
    I think a possible leak point is the linetap valve fitted to the spiral pipework above the comressor (unless it's only just been fitted ??).
    These have a small O-ring as a seal and it tends to fail over time. When you get the repairs done have that removed and replaced by a brazed access point.
    P.S. Like the fridge contents:-
    Jack Daniels and Coke !
    Dec 2005
    South East England
    56
    155
    WOW! The compressor looks like an early hermetic (the motor & mechanical parts are sealed within the case) as on modern fridges & not belt drive as I first thought it would be. It's done unbelievably well to last 50 or 60 years. These days it's exceptional to see 15 years from a compressor on a domestic fridge, even less on the newer non-CFCs. From what you say it sounds like the leak is on the low pressure side of the system (that's figuratively speaking because when running the low side will be above atmospheric pressure) as when off the low side pressure rises as it equalises with the high side & the increased pressure will exacerbate a leak. I can see what we call a line-tap valve on the pipe above the compressor -that's what we use to access sealed systems for diagnosing & recharging with a pressure gauge. These line-tap valves are notorious for leaking after time as the 'O' ring seals on them deteriate. It's probably that leaking or if you're very unlucky there's a leak on the low side somewhere. A good repair shop will replace this valve with what we call a Schraeder stub that is much less likely to leak over time.
    I'm 99% sure it'll be R12 that it's on, but as it's no longer available the alternative R409a will have to be used. R22 is generally used for airconditioning in buildings & I've never heard of it being used in domestic refrigeration applications unless anybody else knows different?
    Feb 2006
    10
    Thanks so much for the info Phil68!
    I don't believe the problem is the line tap because of
    whats happened over the past few years.
    Here is the time line of events
    I got the fridge about 6 years ago from my Grandfathers
    shed.
    It would not cool but the compressor was working.
    I took it to a shop for a work over. They got it working
    and delivered it to my house.
    It worked fine for about a year until I decided to defrost
    it. I turned off the power and let it sit a couple days to
    give it a good cleaning.
    When I turned it back on it wouldn't get cold, it would
    cool but only to about 55 degrees.
    So I took it back to the same shop. It was at this point
    they installed the line tap and re-charged it with *****.
    I picked it up and never turned off the power again.
    I would just use a hair dryer to defrost it while the power
    was on. About 3 years went by with no problems.
    Then I went out of town and my breaker box flipped a
    breaker, the one my fridge was on. The fridge was without power
    for about 72 hours. When I got home and turned the
    power back on the fridge would not cool past about 55 degrees.
    The exact same thing that happened a few years earlier
    when the power was turned off for a extended period
    of time.
    So from what you said I'm guessing the leak is on the
    low pressure side of the system? Is that something
    a repair shop can fix with this type of compressor?
    Thanks again! I'm going to go with the guy who said R12.
    Oct 2004
    Scotland
    1,454
    LOL
    Check out the last picture.
    I take it you have put the pieces of board there to help cut down the noise?
    Are you sure its sog and not under condensing?
    Chillin
    and go get a cuppa
    Feb 2006
    10
    No I haven't put any board in there. That's not board, its
    some kind of insulation material, and it appears to be
    original. Only thing I've done is paint the old girl maroon.
    The compressor hardly makes any noise at all, it you get
    real close you can hear a slight puring noise, but that's it.
    When its fully charged I have to keep the thermostat on
    about 5 (half way point). If I turn it up it will freeze everything
    in the fridge.
    I read on another web page that these old units need
    between 4 and 8 ounces of *****. Does that sound about
    right to you guys?
    May 2004
    southern england
    86
    is there a sploge of coloured paint on the compressor body, pale or light blue would indicate R12. Cannot remember R22 being ever used on domestic refrigeration. Red and dark green paint means run away fast. (methyl chloride) with no known alternatives.
    it's only a fridge, fix it. ;)
    Feb 2006
    10
    I haven't seen any paint on the compressor at all.
    But I know for a fact its *****, I remember the last guy
    who charged it saying something like "Ah this uses the
    old *****...".
    To bad he isn't around anymore for me to call.
    But from what folks here have said I'm feeling very confident
    its R12. The guy who told me R22 said something like:
    "R12 is only for old automobile air conditioners, R22 is what
    you need." So I'm starting to think he didn't know what
    he was talking about.
    Oct 2004
    Scotland
    1,454
    Some leaks are smaller than a nit on a fleas tit.
    LOL
    Havent heard that one before.
    Chillin
    and go get a cuppa
    Dec 2005
    South East England
    56
    155
    Quote Originally Posted by Philco
    old *****...".
    Yep, the guy who told you R22 is definitely talking out of his chuff, go with the guy who said R12. Only he'll be putting in the alternative, which is R409a. Also get him to change the line-tap valve for a Schraeder valve. Let us know how you get on
    Feb 2006
    10
    Will do...
    I've got her going in the shop tomorrow. I'll let yall know
    how it turns out. Thanks so much for all your help fellows.
    Feb 2006
    64
    Smile Re: Help Please: R-12 or R-22
    shed.
    of time.
    I would ask the shop to pressure test system using dry nitrogen, and spray diluted fairy liquid round suspect joints, this should reveal leak for repair before evacuation & re-charge. you can use R413a (R49) as a dropin replacement for R12.
    Aug 2005
    iraq
    67
    130
    hi
    all refrigerators i have seen in my life is R12
    so your is R 12 also
    dont be affraied ,,,charge with R12
    thanks
