Results 1 to 13 of 13
Thread: Pipe size
09-07-2013, 07:57 PM #1
Pipe size
Evening all,
Got myself in the brown smelly stuff today at work got the size of the pipe work wrong on a cut and shuffle was wondering if there was a tool out there which was avaliable to prevent me doing this again. I've seen the copperciser advertised but it only seems to be across the water.
Charlie
09-07-2013, 09:32 PM #2
Re: Pipe size
installation manual?
09-07-2013, 10:17 PM #3
Re: Pipe size
1. Get a large keyring.
2. Cut off short sections of different pipe sizes.
3. Scribe pipe size onto offcut.
4. Drill keyring sized hole in each offcut.
5. Fit offcuts onto keyring.Brian - Newton Abbot, Devon, UK
09-07-2013, 10:22 PM #4
Re: Pipe size
then he'd be walking around with a lump in his pocket
last resort vernier calipers-maybe metric and imperial- to ensure lagging is correctly sized too
-( we all fluff up pipe sizes- i got stung on a mitsi 3.5kw power inverter- every 3.5kw 410a system is 1/4,3/8 -bit late when u run 30 mtr of pipework,in a bulkhead ceiling- no access to rectify- meant to be 1/4 and 1/2!!!!!!
learnt from that mistake
09-07-2013, 10:42 PM #5
Re: Pipe size
I got this this thing from HRP many years ago
it comes in really handy especially with the larger sizes that I don't use too often,
I cant imagine it would be too hard to make if you couldn't find one
15-07-2013, 07:28 PM #6
Re: Pipe size
After time you will be able to tell them by site. When I first started in the field I had trouble identifying pipe size but after a year it was just like another reflex to know the pipe size by looking at it.
15-07-2013, 07:36 PM #7
Re: Pipe size
One of the typical fridgy's quality, is to tell the size of a pipe in the dark. It takes some time but it grows into a second nature.
It happened to all of us.
21-09-2013, 08:20 AM #8
Re: Pipe size
After installing A/C for 35 years pipe size is my only superpower ...... one look and i know what it is !!!!! its a skill that a lot of us have.......... but no good for fighting crime.....
21-09-2013, 12:05 PM #9
Re: Pipe size
Get a cheap vernier caliper or use an adjustable spanner and then measure the gap with a tape. Had a few things where its turned out to be metric fridge pipe so having something more accurate the eyesight is a good backup.
21-09-2013, 12:13 PM #10
Re: Pipe size
normally the laggin is a giveaway- its stamped on!
31-10-2013, 08:53 PM #11
Re: Pipe size
01-11-2013, 02:46 AM #12
02-11-2013, 08:37 PM #13
Re: Pipe size
if it's 7/8 and under, try a flare block. When you can tell just by looking...you're on your way
