Originally Posted by
RANGER1
mfmsheri, what the latest on this problem after draining oil from refrigerant side of oil cooler? I guess you would expect a 50 deg C oil temperature under all conditions. Is this the only compressor with high oil temperature? What is discharge temperature & is suction & discharge pressures "normal" for this plant?
